C4 Questions
C4 Questions
Taking the old 5 speed out and putting a C4 in, my question is from what i understand there are two different C4's which one is recommended or does it really matter?, and will my stock driveshaft fit and will the crossmember i have for the T5 work with the C4??????Also, on the dyno my car made 260 hp, currently with the 5 speed it goes 12.50's @ 107, what converter do you guys recommend?, I plan on putting a transbrake in next year but for the rest of this year ill pry footbrake it for now.
RE: C4 Questions
The C4 will work with your current driveshaft and crossmember. And yes, there are 2 different type C4s. One just has a larger bellhousing, and the other's is smaller. Neither one is preferred, they will perform the same. With the larger bellhousing, you will need a 164 tooth 50 oz flexplate. You can find these easily off an AOD car. The smaller bellhousing requires a 157 tooth 50 oz flexplate. As far as a converter, if your running 12.50s, Id recommend a 3000 stall. However, is that 12.50s on nitrous? If so, get a converter with anti-ballooning plates.
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
treesloth
09-28-2015 07:03 AM
