CAN'T GET THE STANG TO START
i went to go start the stang an it will not start it is a dd when school is n but n the summer it just stays n the garage but i just drove it yesterday so if you guy have any suggestions on were to start looking for the problem plz post em(it will crank but dont even act like it wants to turn over)
THANX
THANX
RE: CAN'T GET THE STANG TO START
You only need three things to get it running. air, fuel, and spark. You can probabyl rule out air right away. So now check for spark. Are all your wires in place? Any of them get damaged or melt? Pull out some plugs and ground them to the engine or something while someone else cranks the engine. Do you see a spark? If you're getting air and a spark, next it's time check the fuel supply. How's the pressure? Do you hear the pump engaging for 1 second when you first turn the key forward (even before you try to start it, just with the key in the on position?)
Since it ran yesterday, I'm going to assume you din't do anyting to the dizzy, cap, rotor, etc.
