Coolant temp sensor placement??
Old 07-31-2007, 12:12 PM
Tims 88GT
Tims 88GT's Avatar
Default Coolant temp sensor placement??
Kinda a dump topic right? Wrong... my question is where is the best place to put a CTS at? Because you can place them in the diff corners ofthe intake and get diff readings right? Say for instance I have the stock one in theleft front corner and it reads a good temp. But I have a mechanical in the right rear and its telling me she is hot. Like 210 at idle, 200-205 getting on it with a 180 thermo. But I am not worried becuse the temp comes right back down. I am thinking its because that sensor is like in a pocket and the water is kinda trapped there becuase it does not travel through the intake. Also the rear of a 302 is warmer than the front but I do not know by how many degrees? So Is my thinking correct or do I have a problem?
Tims 88GT is offline
Old 07-31-2007, 12:14 PM
mattdel
mattdel's Avatar
Default RE: Coolant temp sensor placement??
your thinking correct.
keep in mind that the fan is doing a little bit to cool the front of the motor down, and also the coldest stream of coolant goes through the front of the motor first.
mattdel is offline
Old 07-31-2007, 12:19 PM
Tims 88GT
Tims 88GT's Avatar
ok i am getting somewhere fixing my problems then. PS I just bought a be cool rad what a nice piece. The best rad I have ever had my hands on. I am going to try something, if it works ill let ya ll know, if not no biggie. be back in a lil while.
Old 07-31-2007, 03:20 PM
Tims 88GT
Tims 88GT's Avatar
ok well i just got done messing with the ride. What i did is bought some 1/4in id hose, 3/8 male to male fittinganda 3 way 3/8 t fitting. I took the stock fitting that goes in the manifold for the coolant to run throught the tb and stuck it in the top of the t fitting, then stuck the stock CTS sensor in the side and the male to male in the bottom of the t and into the intake. Then hooked up the tb so coolant runs through it. Well once that was a mod to make hp. but not really becasue i droped a lot of temp in the rear of the motor by hooking the tb coolant lines back up. like 20 degrees. something to think about guys.
Old 07-31-2007, 03:58 PM
tmajikman
tmajikman's Avatar
I had a guy tell me they were useless, but I did not listen to him, I left mine attached and I am very glad I did. It is nice to see some real proof of this arguement finally.
tmajikman is offline
Old 07-31-2007, 04:41 PM
FivePointOhh
in limbo
FivePointOhh's Avatar
ok so let me get this straight. you hooked up your tb lines to cycle coolant from the rear of the manifold to the front of the manifold and it drops total coolant temp by about 20 degrees? did that drop yoru total temp or is it just more efficient?
is this known as the "tb bypass" i've heard of this before i think
FivePointOhh is offline
Old 07-31-2007, 05:16 PM
tmajikman
tmajikman's Avatar
I think it dropped the temp from the rear of the motor 20 degrees, not the complete motor, as he mentioned that he place a temp probe in severeal spots around the motor. Tim mentioned the front of the motor was cooler in the beginning of the thread. Once he hooked up his coolant lines to the tb it made the back side of the motor cooler as well. That is what I got out of his information.
Old 07-31-2007, 06:41 PM
ZachW04Stang
ZachW04Stang's Avatar
ORIGINAL: Tims 88GT
What are you doing with the aluminum one you had before??? My stocker is missing a bunch of fins at the bottom.
ZachW04Stang is offline
jwog666
12-27-2021 08:09 PM
mrtrodonet
09-19-2020 03:12 PM
Dathan
10-05-2015 05:52 AM
wraith777
09-28-2015 10:49 AM
96stang3.8
09-10-2015 06:42 AM
Quick Reply: Coolant temp sensor placement??
