Rounded the bolt...how do i get it off!!!!!!!!!
RE: Rounded the bolt...how do i get it off!!!!!!!!!
Happened to me one time with a starter bolt, my neighbor used a drill with reverse and a small titanium drill bit he coated in motor oil (to lower temp of the drilling so it doesn't freeze up). His idea was to drill within the bolt then use a larger bit and the reverse function to pull it out. What ended up happening was the we drilled into the center of the bolt and ended up using a hammer and a large flat-head screwdriver and tapped it into the center of the bolt and by hand reversed it out. Don't know if any of this helps its just my limited experience. Good Luck!
Smoke wrench or those bolt outs that sideways posted are your easiest optoins. You may be able to unbolt the headers from the heads and drop it all out as one piece , but you will have to have the car WAY up in the air to get it out.
ORIGINAL: mjr46
just cut it off with a cut off wheel
then replace with a non rusty bolt...and next time spray them with some penatrating oil and let them soak over night
ORIGINAL: BlackBetty93GT
thanks sidewayz...im going to pick one of those sets up tomorrow!!
