Putting in Rear Suspension
Old 08-01-2007, 09:36 AM
Legally_Blown
Legally_Blown's Avatar
Default Putting in Rear Suspension
I'm not sure if this qualifies as a technical question so plz move it if it's not. But anyway, I just ordered some Upper and Lower Control Arms from UPR and some Lakewood 50/50 Shocks. If it doesnt come with an instruction manual, could someone tell me exactly what I need to do to put em on myself? pics would help if possible. Thanks.
Also, i've never done anything with suspension so I have very little knowledge of how to do this.
Legally_Blown is offline
Old 08-01-2007, 10:13 AM
w8less
w8less's Avatar
Default RE: Putting in Rear Suspension
its not terribly difficult i have done it a few times. the lakewood 50/50s do come with instructions if i remember correctly. the hardest part will be raising or lowering the rearend to take load off of the bolts
w8less is offline
Old 08-01-2007, 10:20 AM
AdderMk2
Banned
AdderMk2's Avatar
usually I jack up the rear end of the car under the diff, then support the frame with jackstands. then hop in the car and unbolt the top of the shocks. hop back out and slowly lower the rear axle down, the shock will come out of the body, and you can then unbolt them from the axle.
Leave them off. Now do your control arms ONE AT A TIME.
whn you're done with the control arms, bolt the shock to the axle and slowly raise it back up under the car. make sure you align the shocks with the mount holes. hop inside, bolt them back in, lift the car, remove the jackstands. put the car back on the ground..... done.
AdderMk2 is offline
Old 08-01-2007, 10:48 AM
blk40th
blk40th's Avatar
he couldnt havesaid it any better.
blk40th is offline
Old 08-01-2007, 11:27 AM
FivePointOhh
in limbo
FivePointOhh's Avatar
ORIGINAL: AdderMk2
and thats how the cookie crumbles!
FivePointOhh is offline
Old 08-01-2007, 01:09 PM
Legally_Blown
ORIGINAL: AdderMk2
Sounds simple enough. thank you.
drfister
05-03-2018 10:38 PM
alymac
08-26-2015 07:46 AM
Mobiusone stang
08-24-2015 04:08 PM
Black_GT_02
08-20-2015 01:26 PM
robjh22
08-17-2015 07:35 AM
Quick Reply: Putting in Rear Suspension
