Hatch Latch
Hatch Latch
I've been having problems with the latch on my hatch for a while now. I adjusted the latch post, lubed the latch, and bent the latch on the hatch back to it's original position (it got bent out of place and the bolts were hitting against the body, not letting the hatch close at all), and it'll latch fine, and stay latched regardless how hard you tug on it. As soon as I take a semi-sharp turn, or hit even the smallest bump, it pops open, and it's annoying the hell out of me (especially at night when it looks like I've got a strobe light in my car....). Would it hurt anything to soak it in an acid solution, similar to what's used to clean bolts and stuff? Are their any plastic/rubber parts that'll get eaten away?
Also, anybody know if Mustang hatch latches are identical to Capri hatch latches on the bubble hatches? I vaguely remember reading somewhere that they were different, but my memory could be failing me (and hopefully it is).
Soak it in acid, scour all the junkyards for a Capri latch, or just get a Mustang latch?
Thanks
Thanks
RE: Hatch Latch
I'm looking at a Mustang latch on eBay right now, and it looks almost identical, except the power release portion of it. Could I get a power-release hatch and just cut away the power-release components and fit it up?
RE: Hatch Latch
I've played around trying to shut it a few different ways, all to no avail. I think my right hinge pin may be bent, there's almost no gap between the hatch and the body on that side, and they're maybe 1/16"-1/8" gap on the left side, could this be the problem? Or just a ****ty latch?
Thanks for the reply!
RE: Hatch Latch
Does your latch post have the plastic on it? If it doesn't 50resto sells areplacement. My hatch ratttledalot until I replaced mine. Now it doesn't rattle at all. $hit was giving me a headache....
Boostaddict
Lethal Performance
10-01-2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
10-01-2015 08:57 AM
