under drive pulleys
Old 08-01-2007, 09:25 PM
shawnk007
shawnk007's Avatar
Default RE: under drive pulleys
Ive never had an issue with mine. If your that worried, just install the crank pulley. Thats where the added power comes from anyway....
shawnk007 is offline
Old 08-01-2007, 09:33 PM
Texas5.0
Texas5.0's Avatar
ORIGINAL: MEM 302 5.0L
just get a better alternator...that charges better
i upgraded to a 130 amp
Whats a stock alternator?
Texas5.0 is offline
Old 08-01-2007, 09:34 PM
MEM 302 5.0L
MEM 302 5.0L's Avatar
idk ...its less than 100 though..either 75, 85, or 95...cant remember
MEM 302 5.0L is offline
Old 08-01-2007, 10:18 PM
dimebag
dimebag's Avatar
underdrive pullys... never really wasted my time...
and **** w. stock pullys my **** drops idle and voltage alot w. stuff running
nothing runnin its at 14 volts, and 750
ac on and blower full blast it wont idle, itll die
and other **** on its not too good either
but i never use my heat/ac so who cares
dimebag is offline
Old 08-02-2007, 04:06 AM
pat
pat's Avatar
I guess i have to carry a jumper cable then, i already put a 140 amp on , but im still worried, the volt gauge stays in the middle when im on the gas, and when it idles it drops one bar below the middle so i guess thats what worrys me.
pat is offline
Old 08-02-2007, 04:46 AM
85GTsleeper
85GTsleeper's Avatar
you will only have to remotely worry about voltage loss if your at an idle for a veryyyyyy long time
85GTsleeper is offline
Old 08-02-2007, 06:30 AM
Tony71502
Tony71502's Avatar
another way around it is to get aluminum pullies...not steel... they make them lighter instead of changing the size of the alternator pulley.....
What? They do both.... whats the point of sacrificing performance(although minimal) by keeping the alt pulley the same when using aluminum. My UD pulley kit is aluminum and indeed has a smaller alt pulley. But regardless, it runs fine.
Tony71502 is offline
Old 08-02-2007, 08:33 AM
MEM 302 5.0L
hmm i heard that some brands dont change the size..lol maybe its just me[&:]
Old 08-02-2007, 08:40 AM
jthorn9
The Godfather
jthorn9's Avatar
I only had issues with the U/D pullies that came on the car when I bought it last year. They had blue U/Ds but no alternator pully, as soon as I put the BBK on there with the alternator pully, problem solved. Now my big stereo system puts a nice drain on the power in that I can't hold a charge for longer than 30 minutes with that damn thing on and I'm sitting still, but other than that, squeeky clean.
jthorn9 is offline
Old 08-02-2007, 11:41 AM
88_cobra
88_cobra's Avatar
maybe a dumb question, can u run ud pulleys with a sc?
88_cobra is offline
Quick Reply: under drive pulleys
