trouble installing transmission!!
We are installing a 5-spdtransmission into a 89 5.0 stang. We are having problems gettting it to line up tho. The input shaft in particular is whats giving us trouble, we cant get it lined up.
RE: trouble installing transmission!!
u may have moved the clutch disc funny, do u have line up tool? make sure the disc is lined up
ORIGINAL: mattdel
put it in gear and spin the output shaft
your better at eating stripper poon
When I did my clutch it didn't go in the first time around....had to take it out and then it slipped in the second time with no problems. I suggest you try the same.
In addition to all the other tips provided, one time I peened the edge of the pilot bushing over, very slightly, when installing it and the input shaft wouldn't go in. So... If you can see it, you might want to check it out.
05, 95, forum, gt, havint, install, installimng, installing, mustang, problem, reinstalling, spd, tranasmission, transmission, trouble
