pre ignation.
Old 08-02-2007, 04:28 PM
Tims 88GT
Tims 88GT's Avatar
Default pre ignation.
Hey guys I am having a mid rpm like 3k and up pre ignation problem. Timing is like12, fp is 46 withvac off. I can not figure out how to get it to stop. I added a lot of fuel and a lil timing. still does it. I do not know what to do next. I do not have a CEL. Mods. Lunati cam, afr 165 head, 24lb injectors, 80mm maf calibrated for 24's, 190lph fuel pump, aeromotive AFPR. thats about it.
Tims 88GT is offline
Old 08-02-2007, 04:46 PM
mattdel
mattdel's Avatar
Default RE: pre ignation.
any air leaks at all? intake gaskets, intake tube, vacuum,
mattdel is offline
Old 08-02-2007, 05:08 PM
67mustang302
67mustang302's Avatar
Also what is your compression ratio and what are the specs on the cam, and what fuel are you running?
67mustang302 is offline
Old 08-03-2007, 03:55 PM
Tims 88GT
Tims 88GT's Avatar
compression is stock. cam specs do not have anything to do with this problem. I have used it many times. in a blower motor as well, never once had a problem.
Old 08-03-2007, 05:05 PM
67mustang302
If you think cam timing has nothing to do with pre-ignition and detonation, then you don'tunderstand pre-ignition and detonation. Your intake valveclosing point has a direct effect on your dynamic compression ratio. There's a reason I asked what the cam timing was, and what fuel you're running. And is your static CR stock, or close to stock? Different heads/gaskets will change it unless they have the exact same chamber size and exact same gasket volume. Also, how do you know it's actually pre-ignition, and not just detonation?
Old 08-03-2007, 06:03 PM
samseed101
samseed101's Avatar
ORIGINAL: 67mustang302
That was going to be my question as well. Either way, try running a colder spark plug...maybe one range colder. Also, you may have carbon deposits that could contribute to both conditions. Glowing carbon deposits can stick to hot exhaust valves and cause pre-ignition. Carbon deposits also form a heat barrier. And they can raise compression. A little seafoam could take care of carbon.
samseed101 is offline
jwog666
12-27-2021 08:09 PM
spectreman
03-31-2016 09:26 PM
folivier
10-02-2015 05:34 AM
Gabe_mlcc
09-07-2015 11:56 PM
89GTstang
01-27-2004 07:27 PM
Quick Reply: pre ignation.
