radiator
Old 08-04-2007, 09:52 AM
GaryBisiniere
GaryBisiniere's Avatar
Default radiator
i am in need of a new radiator because my car slowly overheats during the summer. i was woundering how the summit aluminum radiators are? do they work as good as the fluidyne or is it worth just spending the 400$?
also if i do not need the tranny cooler can i still use the radiator if i do not hook the cooler up?
thanks
GaryBisiniere is offline
Old 08-04-2007, 12:08 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
Default RE: radiator
yes the aluminum ones work great...they have increased fin size for greater volumne and cooling capacity as well as aluminum disipates heat quicker.......and if you don't need the tranny cooler then don't hook it up it'll be fine for a manual equiped car
mjr46 is offline
Old 08-04-2007, 12:12 PM
GaryBisiniere
so the summit aluminum radiator will do the trick! sweet i get to save 200$
Old 08-04-2007, 12:15 PM
mattdel
mattdel's Avatar
how do you know the radiator is bad? hows the fan clutch?
mattdel is offline
Old 08-04-2007, 01:55 PM
stang8689
stang8689's Avatar
Ford Racing aluminum is only $245 at c.j's
stang8689 is offline
Old 08-04-2007, 02:15 PM
GaryBisiniere
i have a decently built motor and a stock radiator.... i have an electric fan and the temp slowly keeps rising....
Old 08-04-2007, 02:24 PM
fordguy17
fordguy17's Avatar
ORIGINAL: GaryBisiniere
if it startst to rise in traffic, than you don't have enough fan. if it starts to rise while cruising then you don't have enough radiator.
but yeah i used that 179 dollar one from summit and it worked great. its pretty big and will take up a lot of room but it does fit. i had to trim my battery tray...
fordguy17 is offline
Old 08-04-2007, 02:29 PM
FivePointOhh
in limbo
FivePointOhh's Avatar
i have the summit rad....it is slighter bigger than stock.....actually alot bigger than stock. very nice fits well and you'll have to modify your stock brackets to make it fit, at least i had to.
http://i157.photobucket.com/albums/t...6/DSCN0020.jpg
FivePointOhh is offline
Old 08-04-2007, 02:39 PM
fordguy17
fordguy17's Avatar
[IMG][/IMG]
here is a pic of mine...
Old 08-04-2007, 07:17 PM
GaryBisiniere
ORIGINAL: fordguy17
thanks for all the replys! can you post the link to the 179$ one cause all i see is the 279...
and what size motors do you guys have?
Quick Reply: radiator
