AOD removal
Old 08-04-2007, 11:18 AM
91lxstang
91lxstang's Avatar
Default AOD removal
Whats the easiest way to remove my aod tranny from my fox? I know the driveshaft, tranny crossmember, shifter, h-pipe, and linkage has to be removed. But what is the easiest way to get to all the bolts on the bellhousing. Lower the tranny down alittle and use long swivel extensions? Anything im forgettin?
91lxstang is offline
Old 08-04-2007, 11:40 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
Default RE: AOD removal
yeah.... disconnect battery...remove starter and inspection plate to access torque convertor bolts and lowering back of tranny to gain easier access to upper bolts works well
mjr46 is offline
Old 08-04-2007, 11:59 AM
91lxstang
91lxstang's Avatar
ya sry i did forget the starter but i got the other stuff
Old 08-04-2007, 12:10 PM
red9535
red9535's Avatar
You can get to all the bellhousing bolts, no problem.. Make sure you get the torque converter unbolted from the flywheel.. you can test this by turning the torque converter with your hands.. it should spin freely if it's seperated. That's all taht holds it onto the engine.. bellhousing and tq converter to flywheel. After that, get a jack under the trans to hold it up.. they make special attatchemtns for the jack to hold up the trans.. then take off the trans mount, unbolt the driveshaft from the rear axle and pull it off of the output shaft of the trans.. get ready for a big leak.. drop her on down.. gota have your car jacked up pretty high to be able to pull it out..
red9535 is offline
Old 08-04-2007, 03:53 PM
shawnk007
shawnk007's Avatar
The torque converter wont spin if its unbolted. It has studs through the flexplate so it'll still be connected.
shawnk007 is offline
Old 08-04-2007, 09:12 PM
red9535
red9535's Avatar
ORIGINAL: shawnk007
You sure about that?
red9535 is offline
Old 08-04-2007, 09:13 PM
shawnk007
shawnk007's Avatar
100% positive
Old 08-04-2007, 09:21 PM
red9535
red9535's Avatar
We're both right. Just speaking in different contexts. Once you unbolt the flywheel, in order to drop the trans you have to seperate the trans from the engine. The test for if it's seperated from the engine at the bellhousing is by trying to turn the TQ converter. If it's spinning freely, the trans and engine are seperated, and you're ready to drop.
Pardon my comment before, I didn't realize that we had read and interprited his question differently.
red9535 is offline
Old 08-04-2007, 09:27 PM
shawnk007
shawnk007's Avatar
Im sorry, I still dont understand how your explaining this. What I'm saying is the torque converter has studs welded on it that slide in the flexplate holes and uses nuts to secure it. Unlike a chevy, that has nuts welded on the converter and uses bolts to secure the flexplate to the converter. Sorry if im explaining info that you already knew, but thought this was a more detailed explanation.
Old 08-04-2007, 09:38 PM
red9535
red9535's Avatar
ORIGINAL: shawnk007
Right.. and if you tried to drop the trans while the studs were still slid into the flex plate holes, it would either tear the studs or pull out your TQ converter, depending on how you did it. So, what i'm saying is, the way to test that your engine and trans are seperated (and those studs you're talking about are out of the flex plate) is to attempt to turn the torque converter by hand. If it spins freely, then those studs are free, and you can drop your trans without damaging anything still attached.
red9535 is offline
Quick Reply: AOD removal
