Twisted Wedge vs Vic Jr's
RE: Twisted Wedge vs Vic Jr's
ORIGINAL: Jasperstang308
so the victor head is better than the high ports?
here are your high ports.....
here are the 185 CHI heads (the SMALL chi heads!!!)
there is a pretty big different in performance in going from a high port to a CHI head. and like i said, thats the 185cc runner head - they have better flowing heads than this (225 heads flow 295 @ .500, and the 258 heads flow 305 @ .500)
yes, there are ported larger runner high ports that flow better, but all of the CHI heads numbers are unported - not to mention the flow of the 185cc head with a smaller runner is going to keep a better velocity at lower rpms for better power off the line as well as in the higher rpm range
ORIGINAL: FullAuto
The TEA Highports are pretty much a direct comparision in price and flow against the CHIs. I'd take the Highports too. A Victor and basically every other canted valve head will beat them.
ORIGINAL: my77stang
The 225 CHI and the 225 TEA Highport are within $45 of each other. That's probably the closest comparision you're going to get. The TEA Highport wins.
If you want to run a solid roller, the CHI are $500 MORE than the Highportfor a complete set. That's retarded.
Well, a few things. First, if you have 4.11 gears and TFS TW heads on a 302 and only ran 13.6, then as a 347 there's still aLOT of potential left, especially with a bigger cam. I've run 13.40's in my 67 which has a race weight of around 3,200 with me and fuel in it, and that's with a 4 speed manual and a 3.00 geared diff with AFR 165's(comprable to TWs), on street tires and shifting it a tad early(hope to find out what it can really do in another week). With a bigger cam and more cubes, those TWs with 4.11's in a light car should get you into the low 12's on street tires if you set everything up right. Your heads still have plenty of room to improve your et.
That being said, the best bang for your buck head will prolly be the CHI's, they are more expensive than other heads, but the hp/$$ vaule as far as heads go is unbeatable. They'll require a bit of work but they can make a 347 produce a CRAPLOAD of power. Go to their site, the Engine Master's Challenge got a 366 Cleve block to produce just over 600hp at the crank on pump gas at 6,500rpm with a flat tappet cam. The other full race heads or the larger CHI heads will yield more power, but will cost more. It's hard to beat a good canted valve head like the CHI though, and it's different.
ORIGINAL: 67mustang302
^ exactly.
i dont see to many 350ish cubic inch motors making that kinda power with windsor heads even with custom roller cams. plus i dunno why everyone thinks the CHI heads takes some work to get them in. you buy the right friggen intake from them, and use headers for a 351c swap and you shoud be good to go.
btw fullauto, what kinda hardware comes in the high ports? CHI uses ferrea valves and isky springs (a.k.a. GOOD hardware).
