How much horsepower can a stock fuel pump handle?
Old 08-05-2007, 01:06 AM
91blackmustanggt
91blackmustanggt's Avatar
Default How much horsepower can a stock fuel pump handle?
I think my car should run mid to low 12s with the mods I am currently doing. I will be running 30lb injectors, and a BBK fuel pressure regulator. Will my stock fuel pump be starving my motor?
91blackmustanggt is offline
Old 08-05-2007, 02:52 AM
greenstreak9205
greenstreak9205's Avatar
Default RE: How much horsepower can a stock fuel pump handle?
well first of, not that we dont believe you or anything but, what mods do you exactly have that you think that you'll be running 12's? cuz 12's with 100% stock suspension and 12's on a good susp setup will make a bit of a difference. but sorry i personally dont kno what hp(ish) the stock pump will allow. either way a new pump is only about $100 so why not?
greenstreak9205 is offline
Old 08-05-2007, 02:58 AM
85GTsleeper
85GTsleeper's Avatar
upgrade to be safe. especially if you plan on using any nitrous or force induction of any type
85GTsleeper is offline
Old 08-05-2007, 07:10 AM
nitrous_bob
nitrous_bob's Avatar
a stock pump will allow you to go 12's no probs as long is it is still good
a 20 yr old stock fuel pump w/ 125k is probably far from good but who knows, you do NOT need 30 lb inj on a 300 hp car, the entire stock fuel system will support over 300 hp. and thats all it takes to go 12's
but again, list your mods and go from there, and as stated b4, for cheap insurance spend the $89 for a 190 pump, then you know you can dip into the 11's
nitrous_bob is offline
Old 08-05-2007, 09:34 AM
92hatchLX
92hatchLX's Avatar
It depends on how he got to that 300 horsepower, supercharger maybe? Yeah he's going to need more fuel pump and more injector.
92hatchLX is offline
Old 08-05-2007, 09:55 AM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
What mods?
PRO50SC is offline
Old 08-05-2007, 11:20 AM
stang8689
stang8689's Avatar
just spend the $100 on a 255 pump and call it a day
stang8689 is offline
Old 04-20-2011, 09:45 PM
a2z488
a2z488's Avatar
i have a 190 pump in my 88 with a bap and was wondering if i should go to a 220 pump or the 190 good?
i have a 88 306 with kenne bell on it 50ib inject. with 90 mm maf.
any info would b appreciated thanxx
a2z488 is offline
Old 04-20-2011, 09:59 PM
stangman33
stangman33's Avatar
well dont quote me on this, but ive heard that a stock fuel pump is very capable of handling up to 500-550 horses, but like the earlier posts said if its a good one, also imo, like the earlier posts said, spend $100 or so and buy at least a 190 or step up and go 255 so that youll be for sure. considering your gonna have the fpr, you can tune it down so that its drivable.
stangman33 is offline
Design1795
01-24-2017 10:38 PM
YoungStangsMan
09-05-2015 07:01 PM
Design1795
08-24-2015 04:41 PM
drumhedd2005
08-13-2015 09:59 AM
89blueslug
08-10-2015 07:20 AM
Quick Reply: How much horsepower can a stock fuel pump handle?
