Dam ford...still wont start.
I just replaced the TFI module.. Car still won't start. It fires and runs for like 1/2 second, then dies. It wont stay running. Any ideas?
heres my awesome explanation of how it does it... crankcrankcrankVROOMdead
RE: Dam ford...still wont start.
thats not a vacuum problem. its a fuel problem. it sounds like your running off the prime, and then the ECM isn't commanding the fuel pump to turn on full time.
thats where i would start looking.
It was doing the same thing it's doing now. Fuel Pump is wired to a switch, so it comes on when I turn it on, and stays on till I turn it off.
Vaccum I was just curious about as well cuz I'm not sure if I put everything back the way it was.
Could it be timing? I had my distributor out, and to put it back in, I got the motor on the compression stroke on cyl #1.. Turned it over to 0 on the HB, then put the distributor in with the rotor pointing to 1. Is that Right?
