Whats wrong with my starter?
Old 08-05-2007, 08:29 PM
pete97GT
pete97GT's Avatar
Default Whats wrong with my starter?
Does anyone know what could cause the starter to stick for a second after the car has been starter? This is what I have already replaced: starter, starter relay, ignition switch, starter solenoid. The motor in my car is a 92 mustang gt motor and therefore has the smaller type starter with one 4 gauge and one smaller wire. This started happending after I put a 130a alt on and was messing with the starter relay, perhaps I hooked the wires up wrong, but I doubt it. The two wires that come of the starter both go to the one side of the relay, correct? otherwise the sarter just stays engaged. help me out with this
pete97GT is offline
Old 08-05-2007, 08:33 PM
mattdel
mattdel's Avatar
Default RE: Whats wrong with my starter?
the problem started after you were messing with the starter relay, and so you went ahead and replaced everything else in the starting system?
wow
mattdel is offline
Old 08-05-2007, 08:36 PM
pete97GT
pete97GT's Avatar
wait is one of the wires coming of the starter the ground??? the smaller one
pete97GT is offline
Old 08-05-2007, 08:37 PM
mattdel
mattdel's Avatar
should only be 1 wire going to the starter.
mattdel is offline
Old 08-05-2007, 08:40 PM
302f150
302f150's Avatar
Are you sure the actual ignition switch isn't sticking? When you turn the key to Start, watch it and see if it sticks for a second before it returns to Run
302f150 is offline
Old 08-05-2007, 08:41 PM
pete97GT
pete97GT's Avatar
well not exactly, I replaced one thing at a time and when that didnt solve the problem and just brought it back and got my money back, so yes i replaced everything but afterwards just put my old stuff back, btw you were the one who told me to replace the starter, no offense. howeverat the time Iwas almost positive that I had wired everything right. however now that I have replaced almost everything i am starting to doubt myself.
pete97GT is offline
Old 08-05-2007, 08:42 PM
pete97GT
pete97GT's Avatar
well like i said i tried replacing the ignition swith, but that didnt solve the problem.
pete97GT is offline
Old 08-05-2007, 08:43 PM
pete97GT
pete97GT's Avatar
well yes there is only one wire going to the starter, however there is a smaller wire that is going to the ignition solenoid that is mounted on the starter
pete97GT is offline
Old 08-05-2007, 08:44 PM
mattdel
mattdel's Avatar
an 87 mustang shouldn't have a starter-mounted solenoid. you should have an external solenoid, mounted near the coil.
mattdel is offline
Old 08-05-2007, 08:46 PM
pete97GT
pete97GT's Avatar
oh, you mean the ignition switch that the key goes in, no that doesnt stick.
pete97GT is offline
Quick Reply: Whats wrong with my starter?
