motor mounts
motor mounts
when unolting the motor mounts, do you unbolt the two smaller bolts that you can see under the headers(headers are off right now), or the large bolt that you can get to under the car? I unbolted the 2 nuts from inside the engine bay and it looks like the motor will slide out over the studs. Also, is there anything UNDER the motor that needs to be disconected or unbolted before i start pullin the motor up?
RE: motor mounts
I would lift the motor just enough to take the load off the long bolts and then slip them out.
Then, I'd do the small bolts.
If the headers are off the car there really is n't much to worry about as you only need to lift the moteo maybe 3/4"........
RE: motor mounts
Just remove the nut on the large bolt thru the crossmember. This will allow the motor to come out. Just pull the motor slowly and if you see something still attached unhook it. There is no way to tell what you already have unhooked and what elce needs removed without seeing it.
RE: motor mounts
ya i guees your right about that lol... but ya i just unbolted the one large bolt from under the car and it was a b*tch. It took all of my strength plus a 3 ft handle lol but i got that bastard off
ORIGINAL: creekrat
RE: motor mounts
thanks alot man..... i was looking at that wire and wondering where it went ... i guess it conencts to the head like you said.
ORIGINAL: r.barn
remember the ground strap on the back of driver side head
and power cable going to starter and low oil sensor wire on pan
jwog666
12-27-2021 08:09 PM
logan409
09-26-2015 07:43 PM
