cLUtCh..?
RE: cLUtCh..?
you could buy the king cobra if you want to be replacing it in a couple months. two of my friends got to replace it after 3months of usage. i would recommend the centerforce dual friction since thats what i have used. its strong and has a soft pedal feel
RE: cLUtCh..?
Im ganna prob order a DF centerforce. A week before the clutch started goin out my car would start shaking after 2000RPM only when the clutch wasnt used., and i called summit and the guy i spoke to told me that my prob was the Pilot Bearing. would that sound about right..?
RE: cLUtCh..?
ORIGINAL: bzlover
I doubt it... the pilot bearing is not being used when you are not using the clutch...
RE: cLUtCh..?
ok 1st off... spec ftmfw... i have one, wont ever go w. another brand
2nd... pilot bearing isnt used w. the clutch pressed in? um... what???? try to rethink that... the shake to me sounds like the flywheel being a lil ****ed up, or the clutch bein messed up badly in one spot... either one would cause the shaking
RE: cLUtCh..?
ORIGINAL: dimebag
the pilot bearing is the bearing that the tip of the input shaft rides in... explain to me how its ever not being used???
hpwrestler220
28
10-18-2008 07:35 PM
