KB Supercharger?
Old 08-07-2007, 12:21 AM
cgarray17
cgarray17's Avatar
Default KB Supercharger?
I am going to save up money for a supercharger in the spring of 08, i have been looking at prochargers and then discovered Kenne Bell supercharger, just woundered what you guys thought about the two, i like how the KB looks andsounds but dont know that much about them, they are both about the same but the KB is cheaper. so any comments or info would be great. Also i am not looking for a high boost just at ether 6 or 9psi.
cgarray17 is offline
Old 08-07-2007, 12:37 AM
Mustangkiler
Mustangkiler's Avatar
Default RE: KB Supercharger?
I got 50 hp on my otherwise stock except for exhaust 94 5.0 on 6 psi. Plan on going to 9 or 10 after i do the heads and get better head gaskets in. They dont make as high as dyno numbers as centros. But i got mine for what it is, instant power and torque. I got great torque numbers 330 peak and stays above 300 from 2500 to 5000. From 190 hp at the wheels to 240. Over 200 hp from 3000 to 6000. Only drawback on the KB is no real way of intercooling unless you use methanol injection.
Mustangkiler is offline
Old 08-07-2007, 12:42 AM
superman5.0
superman5.0's Avatar
nahh f a sc throw a 125 wet on the bitch
superman5.0 is offline
Old 08-07-2007, 01:35 AM
cgarray17
cgarray17's Avatar
So for the extra $500 would the intercooled procharger be better or are they more wear on the engine? And was the KB easy to install.
Old 08-07-2007, 09:55 AM
cgarray17
cgarray17's Avatar
UP^^
Old 08-07-2007, 10:01 AM
AdderMk2
Banned
AdderMk2's Avatar
you would be better off getting an intercooled Vortech setup.
the procharger places the inlet tube right over your driver side headers.... so your always sucking in hot air.
a intercooled vortech wont do that
AdderMk2 is offline
Old 08-07-2007, 10:13 AM
FivePointOhh
in limbo
FivePointOhh's Avatar
go turbo, research that. way moer complicated but much higher benefits
FivePointOhh is offline
Old 08-07-2007, 11:48 AM
67mustang302
67mustang302's Avatar
A lot of what type of forced induction you use depends on your setup, compression, cam, gears etc etc. Turbo or positive displacment superchargers with low gears will lead to no traction on the street and so on and so forth. IT depends on your setup and what you want out of it
67mustang302 is offline
Old 08-07-2007, 03:24 PM
Stanpower
Stanpower's Avatar
ORIGINAL: AdderMk2
Ya ,samseed101( Procharger) has that set-up with that problem but he's making so kind of box or heat shield too draw that heat away? I haven't seen you on the forum that much lately addermk2 Where have you been bud?Good to see ya back!!
Stanpower is offline
GimpyHSHS
19
12-19-2023 01:12 PM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
col2560
09-25-2015 08:59 PM
Quick Reply: KB Supercharger?
