not keeping fuel pressure
Old 08-07-2007, 03:02 PM
green95GT
green95GT's Avatar
Default not keeping fuel pressure
ok so after i leave my car sit for a while it doesn't keep fuel pressure i changed my fuel pressure regulator and my fuel pump. what else could it be
green95GT is offline
Old 08-07-2007, 03:08 PM
MikeVa
MikeVa's Avatar
Default RE: not keeping fuel pressure
You mean after it has been shut off? You are not supposed to have any pressure when it's off, only when the ignition is on.
MikeVa is offline
Old 08-07-2007, 04:10 PM
93 LX FiveO
93 LX FiveO's Avatar
there should still be pressure in the system even if the car is off..
93 LX FiveO is offline
Old 08-08-2007, 05:38 PM
green95GT
green95GT's Avatar
bump
Old 08-08-2007, 05:46 PM
mattdel
mattdel's Avatar
leaking injector, hole in the pickup tube for the pump, or a leak in a line.
mattdel is offline
Old 08-08-2007, 05:51 PM
Derf00
Gentleman's Relish
Derf00's Avatar
ORIGINAL: green95GT
What's "a while"?
an hour? Two hours? Half a day? All day? what?
Derf00 is offline
Old 08-09-2007, 01:17 AM
green95GT
green95GT's Avatar
ORIGINAL: Derf00
ORIGINAL: green95GT
What's "a while"?
probably about 2 hours give or take an hour
Old 08-09-2007, 07:20 AM
luckythirteen13
luckythirteen13's Avatar
ORIGINAL: 93 LX FiveO
no there isnt.
from the moment you shut your car off, fuel pressure will begin to drop because the pump is no longer supplying fuel. within 2 hours of the car being shut off, your fuel pressure should be at or close to 0psi
luckythirteen13 is offline
Old 08-09-2007, 07:34 AM
MikeVa
MikeVa's Avatar
ORIGINAL: luckythirteen13
no there isnt.
YES, Lucky is right.You'll have fuel in the lines, but it won't be pressurized.
MikeVa is offline
Old 08-09-2007, 10:51 AM
mattdel
mattdel's Avatar
wrong. the fuel system WILL leak down slowly, but it should be pressurized above 25~psi for a good 6 hours.
mattdel is offline
Quick Reply: not keeping fuel pressure
