rear end
RE: rear end
Dont forget the driveshaft bolts and the rear brake lines on top of the axle. Dont remember what size those take.
Before you finish tightening the control arms make sure the car is on the ground first with the bolts a bit loose. Dont let the axle hang free and then tighten the bolts or the bushings can bind.
Rear upper control arms to body = 100-105ft-lbs
Rear upper control arm to axle = 90-100 ft-lbs
Rear lower control arms to body = 100-105 ft-lbs
Rear lower control arm to axle = 90-100 ft-lbs
Shocks/quad shocks = ? im not sure.
Dragonus18
09-09-2015 01:21 AM
