whiper motor?/blinkers
Old 08-07-2007, 09:20 PM
ltrayne84
ltrayne84's Avatar
Default whiper motor?/blinkers
ok.. mine is a 90 mustang GT...whipers just stop working out of nowhere... but work when i hit the motor with ohhhh let say a screw driver... new motor time or what??? is the whiper motor a 1 plug or 2 plug??? And.. Where exactly is the flasher relay for the turn signal lights located???
ltrayne84 is offline
Old 08-07-2007, 09:50 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
Default RE: whiper motor?/blinkers
Yeah sounds like a new wiper motor is needed......the flasher relay I believe on some modela was in the fuse box and or behind it but like on my 92 the 4 way flasher is in the fuse box and the turn signal relay is clipped up by the steering column....you have to remove the lower panel to gain access and reach up and get it....that's to say yours is set up that way......best way is get a parts locator manual and apply that to the year of your car
mjr46 is offline
Old 08-07-2007, 09:56 PM
dimebag
dimebag's Avatar
wait wait wait... did both problems start at the same time... or like with in a week or two of each other? do u drive w. ur fogs on alot? i think its ur mfs
dimebag is offline
Old 08-08-2007, 12:19 AM
ltrayne84
ltrayne84's Avatar
well i've been having problems with my blinkers going out... but now that u mentioned it... my whipers did start to go out about 2 weeks after the blinkers did
ltrayne84
ltrayne84's Avatar
Old 08-08-2007, 02:45 AM
neutralpinned
neutralpinned's Avatar
the blinker relay is a quite a b!tch to get to, you're best to take out your seat and crawl up under your dash, its a small gray box about 1in x 1in and has 2 braided wires running to it, ones brown and pink, and ones brown and... yellow? dont quote me on that i'll check tomorrow to be sure for ya. but when my blinkers went out, that wasnt the problem. it was my turn signal switch itself, so i had to get that whole assembly replaced. I'm not sure how common of a problem that is. As far as your wiper motor goes, if its only occasional and you can tap the motor and it works, its most likely gonna be just a new wiper motor.
neutralpinned is offline
Old 08-08-2007, 12:28 PM
MUSTANGMIKE1320
MUSTANGMIKE1320's Avatar
ON SOME MODELS LIK EMY 92 LX THE TURN SIGNAL FLASHER IS BEHIND THE GLOVE BOX UNDER THE DASH IT WAS A PAIN FOR ME TO FIND THAT I DROVE AROUND FOR ALMOST A WHOLE YEAR USING HAND SIGNALS
MUSTANGMIKE1320 is offline
firehorse02
11-16-2015 11:28 AM
UrS4
10-03-2015 06:23 AM
Explosive
10-02-2015 07:45 AM
Drastang
09-30-2015 03:48 AM
logan409
09-26-2015 07:43 PM
Quick Reply: whiper motor?/blinkers
