Injectors
Injectors
What do you gurus suggest for injectors on a supercharged setup pushing 12lbs with AFR 185 heads and RPM intake
I'm torn between 42 and 48 pounders
then...
I do not understand how they are sized as far as Ohms
what do you guys suggest and/or used on a similiar setup
http://store.summitracing.com/egnsea...;x=37&y=11
http://store.summitracing.com/egnsea...;x=20&y=11
Thanks all
Matt K.
then...
Thanks all
Matt K.
RE: Injectors
ORIGINAL: only90s
42s will max out usually around 450 rear wheel horse.....
I have 42s and they were at 96% duty cycle on a run I did with 422 to the wheels so depends what you think you are going for with power.
RE: Injectors
ORIGINAL: MadMan@TheWheel
42lb injectors will support 650hp. Where and the hell are some of you getting your numbers from?
