oxygen sensor
Old 08-08-2007, 08:21 PM
Downset4130
Downset4130's Avatar
Default oxygen sensor
i have a 1990 mustang and just wanted to know if i really need to have them. my set up is long tube no cats. all smog
equipment has been removed.just want to make sure it wont hurt my performance
Downset4130 is offline
Old 08-08-2007, 08:25 PM
88blk5.0
88blk5.0's Avatar
Default RE: oxygen sensor
Yes, oxygen sensors control air/fuel ratios. Without them our computers would end up guessing on mixture ratios and as a result the car would run like crap (and it uses more fuel than is needed)
88blk5.0 is offline
Old 08-08-2007, 08:32 PM
CantStopTheFox...
CantStopTheFox...'s Avatar
+1...the computer needs it
CantStopTheFox... is offline
Old 08-08-2007, 08:44 PM
Downset4130
so i guess i was told the wrong info than... the person helping me the first time around said i didnt need them due to the fact all my smog stuff was off...
Old 08-08-2007, 08:51 PM
88blk5.0
88blk5.0's Avatar
haha nope all cars need oxygen sensors (unless you are running a stand-alone computer and can calculate the proper air/fuel ratios and control them yourself)
My 88 has no smog pump, cats or any of the BS smog piping and when I replaced the h-pipe with an off-road x-pipe I also replaced both oxygen sensors. I noticed a little better gas mileage!
88blk5.0 is offline
Old 08-08-2007, 09:05 PM
Downset4130
ORIGINAL: 88blk5.0
[sm=headbang.gif]i guess there going in... to the person that told me i didnt need them [sm=smiley35.gif][sm=shootshoot.gif]
Old 08-08-2007, 09:12 PM
luckythirteen13
luckythirteen13's Avatar
the smog system and the o2's are only loosly related. granted o2's will ensure the car runs the correct afr causing the car to run cleaner (i.e pass smog) but just because you dont have smog equipment, doesnt mean you dont need o2's your motor still needs them to run correctly
luckythirteen13 is offline
Old 08-08-2007, 09:19 PM
samseed101
samseed101's Avatar
The only way you can get away with no O2 sensors is if you get a tune. you can force the car to run in Open Loop all the time. Then you can manually enter all of the fuel tables. But that's a pain in the ***. If you're at that point,then you might as well just switch to carb.
samseed101 is offline
Old 08-08-2007, 09:24 PM
Downset4130
lucky i like your sig ... yea i just ordered the new o2's the car not done yet i just got the h-pipe in today but thanks for the fast replys and the info. last time i listen to that person dam better yet next time im sticking to a carb
Old 08-08-2007, 10:07 PM
mattdel
mattdel's Avatar
if you need to drill your pipes and make a spot for them, make sure you put them relatively close to where they used to be.
mattdel is offline
Quick Reply: oxygen sensor
