Vaccum lines?
Vaccum lines?
Hey, I'm pretty sure this is vacuum. On the passenger side firewall, theres a lil black plastic thing, and it has a small hose coming out that side that goes to the drivers side firewall where theres a thing with like 4 fittings on it. One is plugged, one has a hose that goes to the intake, and I forget the last one. ANyways back to the passenger side. So theres the small hose out the side, then theres 2 fittings on the bottem side of this, on is a tiny hose that goes into the firewall, the other fitting theres nothing there. Did I just forget to hook one back up or something? Where do they go to?
RE: Vaccum lines?
yea I found an old pic, I did forget to hook one back up. One goes into the firewal, then one dissapears somewhere in the passenger side fender, but I cant find it anywhere, what does it go to?
RE: Vaccum lines?
One is for main vacuum supply(intake hose), another goes to the brake booster, one is for cruise control(if you don't have cruise, plug it), one is for the A/C controls(this one runs to the passenger side firewall).
This should be the A/C vacuum line.
what does it go to?
RE: Vaccum lines?
ORIGINAL: MikeVa
what does it go to?
RE: Vaccum lines?
Check out this thread and see ifit helps... I had the same problem.
https://mustangforums.com/m_3532297/tm.htm
RE: Vaccum lines?
ORIGINAL: pastfast125
Where's the left one go? It's not connected anymore and nowhere to be found.
jwog666
12-27-2021 08:09 PM
Matt's 95 Stang
10-05-2015 07:16 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
LivingInThePast
09-16-2015 12:20 PM
