modified 5.0 lacks power
RE: modified 5.0 lacks power
Even with it running right the C-4 trans with 3.73's might not be enough to spin the tires on a car with a top-end kit on it, esp on sticky tires. It is also close to 100*F in a lot of places.
I would have to second what Samseed said- vaccum leak somewhere.
Also let the motor/ trans break in, fix the EGR, check basic stuff (igniton, timing, fuel filter etc.)
ORIGINAL: bduke
no not really it jjust doesnt seem to have near enough power as it should.
well i know where my egr goes to the motor it has no hose on it and has some suction when i put my finger over it. but the plugs and wires seem to be good. what do yal mean check the ignition? As you can see i dont know a whole lot about this stuf.
[/align]
Get a vacuum tester and make sure thats good, you could also check the compression. Make sure your getting spark to all 8 cylinders. Check your timing too. I bumped mine up a bit when i did my mild build and it helped it run a whole lot better. Side note - our cars (sn95's) dont run all that well without some kindof tuning after any modifications, if you can take it to the dyno. If you are willing to learn buy a handheld tuner.
ORIGINAL: bduke
I'm not so sure why you keep dismissing the possibility of a vacuum leak. You keep saying it's not it. Then you go on and tell us that you can see / feel suction. Then you press on and talk about ignition, plugs, wires, etc.
ORIGINAL: samseed101
That right there is a vacuum leak. If there is some part that doesn't have a hose on it and if you can feel suction when you put your finger over it, then that is a vacuum leak and that can cause the problems you are describing. The bigger the leak (or the more leaks you have) the more problems you'll have.
ORIGINAL: bduke
Samseed is right, it IS a vacuum leak. The EGR must be hooked up correctly or disconnected and plugged.
