modified 5.0 lacks power
Old 08-09-2007, 10:52 PM
  #41
bduke
bduke's Avatar
Default RE: modified 5.0 lacks power
well supposably the motor has just been rebuilt. what do you think caused it?
[/align]
bduke is offline
Old 08-09-2007, 11:00 PM
  #42
bduke
bduke's Avatar
Thanks. I just bought this car so I was kinda worried about an engine rebuild. what kind of tuner would you suggest?
[/align]
bduke is offline
Old 08-09-2007, 11:01 PM
  #43
mattdel
mattdel's Avatar
you can install an inline PCV catch can, to catch the oil
mattdel is offline
Old 08-09-2007, 11:11 PM
  #44
samseed101
samseed101's Avatar
Install the oil / air seperator like Matt said, clean the MAS with MAF sensor cleaner, and fix the damned vacuum leak. Problem solved. You're seriously making this out to be a ****load harder than it really is. This is about as basic as you can get as far as problems. On the "difficulty" scale it ranks right up there with changing oil or spak plugs.
If the engine was recently rebuilt, check teh compression to make sure someone didnt **** something up. If they did, then rebuild. if it's fine after doing the three things listed above, then that's the end of that. It's really not that hard.
samseed101 is offline
Granatelli Sales
03-25-2016 08:01 PM
Granatelli Sales
12-27-2015 06:28 PM
10-09-2015 03:27 PM
2015Ecoboost
09-17-2015 01:48 PM
vintageaion
09-08-2015 10:45 AM
Quick Reply: modified 5.0 lacks power
