tranny problems
Old 08-09-2007, 04:56 PM
Jrichber95GTS
Jrichber95GTS's Avatar
Default tranny problems
I think my transmission is messed up and i am going to take it out but was wondering can i still start my car with the tranny out to see if thats where all the sound was coming from? its a 95 347 with stock t5 5speed.
Jrichber95GTS is offline
Old 08-09-2007, 05:22 PM
89Ford
89Ford's Avatar
Default RE: tranny problems
if you can think of a way to get it to turn over without a starter spinning your flywheel
89Ford is offline
Old 08-09-2007, 05:30 PM
dimebag
dimebag's Avatar
wtf? why wouldnt the starter spin the flywheel? yes dude remove the trans w. the 4 bolts from it to the bell housing and youll be fine
dimebag is offline
Old 08-09-2007, 05:32 PM
BlessedHellride
BlessedHellride's Avatar
If you start it, be sure not to mess with the clutch pedal, or remove your throw out bearing or you will wished you had.
BlessedHellride is offline
Old 08-09-2007, 05:37 PM
89Ford
89Ford's Avatar
oh my bad I was thinking if he removed the bellhousing
89Ford is offline
89Ford
89Ford's Avatar
long day at work[&:]
89Ford is offline
Old 08-09-2007, 05:43 PM
dimebag
dimebag's Avatar
yes DO NOT touch the clutch at all... like no just no dont do it...
and long day? yea i hear that... 10 hours(typical m-f) multiple brake jobs, few oil/etc jobs, ****ed w. a ford automatic in an f150, ****ed w. a POS focus that took literally 10 min to drive on the rack, because *** boy had it so ****in low, and an *** load of sound **** in it... ghey... and a few other things that i just cant remember.... o yea... 2 trailors did wheel bearings on them... again, more i just cant remember, lol
dimebag is offline
Old 08-09-2007, 05:50 PM
89Ford
89Ford's Avatar
what kind of sound do you hear and where does it sound like its coming from? I assume its coming from the trans but if you could be more specific
89Ford is offline
Old 08-09-2007, 05:57 PM
dimebag
dimebag's Avatar
yea hell good point... whats goin on exactly... u may be able to get an answer ... or at least a way w. less work to diag it
dimebag is offline
Old 08-10-2007, 03:58 PM
Jrichber95GTS
Well it pretty much sounds like stuff just clunking around and when i push in on the clutch it kinda tones the sound down a little bit and there is also no evidence of any kinda shavings or whatever in the oil so im hoping its not a motor problem
Quick Reply: tranny problems
