Nex wet nitrous install help pics
OK, I have mounted the bottle, ran the line to the engine bay, tapped the power pipe and threaded in the sprayer. the nex item i assume is to mount the nex brain box and start hooking up the lines? The main quesstion is we do I hook the gas line to? Is that dumb ?
[align=left] [/align]
RE: Nex wet nitrous install help
It it an NX or a Zex? You seem to have combined two different brands
To answer your question, most people hook it up to the fuel test port. If you look at your fuel rail on your passenger side, you'll see something that looks like a valve stem for a tire or something. That's your schrader valve. Remove that valve and replace it with a 4AN to 1/16" NPT fuel rail adapter. You can buy one here for $10. Then you hook the line up to that.
That is what I initially thought and I believe the ZEX kit comes with that fitting. Do you have a close up shot of the valve on the fuel rail?
his is different than yours... simply unscrew the schrader valve, install the adapter, screw on the 90° fitting, anf run the fuel line..
its not hard.... its all outlined in the instructions.... you did read them... didnt you?
no everyone is as smart as u adder they dont need to readcus they are like u...oh so smart and like 16y/0???
ORIGINAL: AdderMk2
ORIGINAL: 86GT 93LX
ORIGINAL: AdderMk2
look on the right side (pass) under the hood
on the fuel rail , there is what looks like a tire valve to the left of the dizzy
you need to back up the lower part, and remove the upper....fuel will spray a little, you can bleed it down by unplugging the inertia switch in the trunk and start the car to relieve a bunch of FP
then use the npt to -an adapter
ORIGINAL: nitrous_bob
yeah but atleast im old enough to smoke, drink and Know better, and spend more time working on cars then i do talking crap on the internet, so that probably means i know more than you rather than how to type which does what for fixing cars????if you spent half your time flaming working on your car you might actually learn something and not **** off everyone you speak to on here. and what is mk2 isnt that some kinda import?? and what are you certifide in? ase certifide parts advisor???anyways it means nothing to me. im just really sick of you and your stupid remarks, and you always jumping the gun and giving faulty advice because you cant read an entire post. so if you dont like it too bad, im going to check you everytime i see a stupid post by you. sorry to steal the thread everyone but little kids need to learn manners and respect for the rest of the adults on this forum
ORIGINAL: AdderMk2
I know there is an insult in there somewhere... but I cant really read that.... you have the grammar of an inbred hick!
ORIGINAL: 86GT 93LX
ORIGINAL: AdderMk2
Luke9222
10-22-2015 11:55 PM
