Installing a 460 in a Fox Coupe?
Old 08-09-2007, 05:26 PM
shaved8750
shaved8750's Avatar
Default Installing a 460 in a Fox Coupe?
Im goin to buy a notchback 4cy. and im planing on putting a 460 in it. Can I use the stock K-Member, rear end?
shaved8750 is offline
Old 08-09-2007, 05:30 PM
BlessedHellride
BlessedHellride's Avatar
Default RE: Installing a 460 in a Fox Coupe?
K-Member yes, with correct oil pan. Rear end, BIG NO NO!!!
BlessedHellride is offline
Old 08-09-2007, 05:45 PM
ahittz24
ahittz24's Avatar
4-cyl cars have 7.5 rear ends that will not tolarate the abuse of a BBF. You need to look into trans upgrade, 8.8 rears will take a good pounding and keep on going. They will support up to the 550-600hp range. special headers will be needed and a special bell housing for the trans
ahittz24 is offline
Old 08-09-2007, 05:49 PM
AdderMk2
Banned
AdderMk2's Avatar
www.bigblockfox.com
AdderMk2 is offline
bz1111
bz1111's Avatar
No to hijack the thread but I have a granatelli K-Member in my 4cyl notch and it will accept a 460, but I am going with 331
bz1111 is offline
Old 08-09-2007, 06:40 PM
79bronco
79bronco's Avatar
Go with the ford 9 inch for the rear end...its alot stronger than the 8.8
79bronco is offline
Old 08-09-2007, 06:50 PM
primetime5.0
primetime5.0's Avatar
ORIGINAL: 79bronco
a built 8.8 will be more than enough
primetime5.0 is offline
Old 08-09-2007, 09:43 PM
stang8689
stang8689's Avatar
460-cool
stroked with heads-really cool
460 stroked with heads in a fox-cool as ****
stang8689 is offline
Old 08-09-2007, 10:36 PM
79bronco
79bronco's Avatar
A stock 9 inch is as strong as a built 8.8
79bronco is offline
mtgldr
02-03-2024 09:00 PM
BOBCATJACK
09-14-2015 02:18 AM
Quick Reply: Installing a 460 in a Fox Coupe?
