Wire harness
Wire harness
I am swapping a V8 331 into my 93 notch 4cyl. This is the first time i have done anything close to this, so I have a question about the harness in the donor car 88 GT vert. Will i have to pull the harness in the 88 to put into the 93, or it is cost effective to buy a new one? I plan on running engine only, ele water pump, no a/c or heat, no lights or blinkers a real stripped down week end racer.
Any help would be great!
J
J
RE: Wire harness
If you are up to the task using a donor harness is fine. If not you can fetch them new for about $200-250 through most catalog houses. I know Late Model Restoration Supply has them.
jwog666
12-27-2021 08:09 PM
Matt's 95 Stang
10-05-2015 07:16 AM
breaking
10-02-2015 01:27 PM
