No voltage at TPS
#24
RE: No voltage at TPS
can someone pull apart there connector, turn the key on and let'me know how much power if any is supposed to be supplied to the TPS...
Per his original post, we should assume he did have the key on.
#26
yes the key is on, hehe, yes i'm dumb, but not THAT dumb
and hoadhunter, i'll check that ground, as i did recently locate the battery to the trunk, everything
else has been working fine after the install.
#28
ur wires are pinched cuz ur not getting continuity at either vref and signal wires. do a continuity test between the black wire at the tps and ground and do the same for signal and vref. Test at power at bat, ground and actual ecm. should only have continuity between ecm and tps, If u ahve continuity at any other location thats ur short open "power' "ground"
jwog666
12-27-2021 08:09 PM
69MustangCoupe393cid
10-03-2015 10:33 AM
TfcCDR
09-14-2015 12:08 PM
