No voltage at TPS
Old 08-09-2007, 08:48 PM
ColinK82
ColinK82's Avatar
Default No voltage at TPS
check engine light came on and code 63 came up. tps sensor or circuit.
tried to adjust the voltager and am getting ZERO. nothing between green and black.
is there supposed to be an imput voltage in the orange wire, and the tps kinda acts like a voltage regulator outputting low volts through the green?
can someone pull apart there connector, turn the key on and let'me know how much power if any is supposed to be supplied to the TPS through the orange
ColinK82 is offline
Old 08-09-2007, 08:51 PM
mattdel
mattdel's Avatar
Default RE: No voltage at TPS
5v reference signal in the red wire
with the key on, you should have around 0.8-0.9 volts at the green wire. doesn't really matter, just so long as its down there and not way up high, or 0
black is ground
mattdel is offline
ColinK82
ColinK82's Avatar
at the green wire i have zero, nothing at all
and went to ford and got a new senor so that's not the issue.
ColinK82 is offline
Old 08-09-2007, 08:54 PM
mattdel
mattdel's Avatar
whats coming through the red?
mattdel is offline
Old 08-09-2007, 08:55 PM
ColinK82
ColinK82's Avatar
nothing, none of the wires have any power
ColinK82 is offline
Old 08-09-2007, 08:56 PM
ColinK82
ColinK82's Avatar
there's no fusible links in line anywhere, and run through no fuses. wires go straight to the computer i belive.
can the a9l just go like that?
ColinK82 is offline
Old 08-09-2007, 08:57 PM
mattdel
mattdel's Avatar
you sure the volt meter selector **** is in the correct spot?
mattdel is offline
Old 08-09-2007, 09:01 PM
ColinK82
ColinK82's Avatar
Yea, thats not an issue.
cars idles like crap, and cant drive at low speeds without the car bucking violently
ever since the like came on
ColinK82 is offline
Old 08-09-2007, 09:08 PM
mattdel
mattdel's Avatar
check the MAF voltage, in and out.
mattdel is offline
Old 08-09-2007, 09:10 PM
ColinK82
ColinK82's Avatar
MAF, why?
ColinK82 is offline
Quick Reply: No voltage at TPS
