nawwwwwwwzzzzzzzzzzz
RE: nawwwwwwwzzzzzzzzzzz
ORIGINAL: samseed101
LoL, it's for the older, blinder crowds on here Their eyes arent what they used to be.
ORIGINAL: my77stang
there you go upping me with a larger pic
lol, but taht is a great setup, i will be looking into it mroe, does anyone know aprice on that? where would i run the fuel line and the nitrous line? out the back?
Scroll further up and you'll see a link to the kit in one of my earlier posts in this thread. It should have all the info you need.
As far as using it on a carb setup, there's an even easier kit to use for that. This is the kit you would want for carbs. And here's a pic of it. You hide it right in the air cleaner assembly.
And if you want a really cheap bare bones nitrous setup that's hidden, take a look at the Sneaky Pete setup. It's runs off two 9-volt batteries and gives you a little kick in the *** when you need it. It's nothnuig great, but it's a good, cheap setup. It comes with 50hp jets and you can go up to 125. It usually runs about $240.
ok so if i went with that hidden setup under the manifold, what does each jet amount to?
if i wanted a total of a 125 shot, each jet would be... 15.625hp ?
does it work like that?
i'm somewhat of a nitrous newbie
