Suspension questions
Old 08-10-2007, 12:29 AM
FuzzyDiceRule
FuzzyDiceRule's Avatar
Default Suspension questions
do fox GT's come stock with rear sway bars
i have a rub in the back, but its only when im turning and the front wheel hits an extreme angle, IE when i put the left front on my driveway, and stress it like that, the wheel doesnt touch, but when i make a hard left onto my street, which goes up at like a 30 degree angle, it rubs, i think it does this because the rear end moves a little bit
also, how hard are panhard bars to install, and who makes the best
FuzzyDiceRule is offline
Old 08-10-2007, 01:18 AM
FuzzyDiceRule
Default RE: suspention
TTT
anybody???
Old 08-10-2007, 01:20 AM
blackout
blackout's Avatar
Why don't you just go look and see if it has a sway bar? I'm pretty sure they come with a factory sway bar but I know mine came with one when I bought it (I looked under my car).
As for the panhard rod, that is an easy install with a jack and some jack stands and your basic hand tools.
-Jeff
blackout is offline
Old 08-10-2007, 01:47 AM
FuzzyDiceRule
ok sweet, my cars pretty low, and i didnt want to check
thats totally the next two or three things im doing, thicker sway bars, and a panhard bar
Old 08-10-2007, 02:20 AM
blackout
blackout's Avatar
ORIGINAL: FuzzyDiceRule
Mine's low too!
Are you going for better handling?Do youalready have some new lower control arms and upper control arms? I don't see anaftermarket sway barfirming up the rear of the car substantially.
-Jeff
blackout is offline
Old 08-10-2007, 01:21 PM
FuzzyDiceRule
yeah, but you dont have GT ground effects, i CANT get my head under it, but ill check later
it was all the way down via the P.O for handling, but ever since i got my 275/40/17 tires, the rearend moves and rubs sometimes, id like to be able to take corners like i usually do, but not have it rub=panhard bar and bigger sway bars
Gene K
10-21-2015 11:37 PM
GimpyHSHS
09-18-2015 12:27 PM
degner122
09-16-2015 07:09 AM
09-08-2015 11:50 AM
raleigh05GTO
09-04-2015 07:09 AM
Quick Reply: Suspension questions
