listen to this $hit
listen to this $hit
so i go to put my oil pan back on last night after replacing the oil pump. the oil pump is hitting the bottom of the pan and has about a 1/2 inch more to go so it bolts to the block. Unfortunatly my old oil pump has been chucked.
Anyone hear about this problem or expierence it? Is there more than one pump? This one i got was a melling from autozone. Thanks!
RE: listen to this $hit
was it a high volume one???? if so you may have to clearence the pump for it to work with the pan. if it's a high volumne one it'll say on the pump tag indicated by mv68hv
ORIGINAL: 88MustangGX
The other thing that is possible (but not likely) is that there may have been a phenolic spacer on the OEM one that is not required aftermarket. Take a look at where the pump mounts. Is there a spacer there? If there is, remove it and attach the new pump directly to the motor.
the pump was only 18 bucks so im sure i didnt get a high volume one. unless they are retarded and picked the wrong one.
No i didnt compare cuz the other one got chucked without me knowing it. I'll have to do some diggin on the sizes of them. thanks all
breaking
10-02-2015 01:27 PM
KingRando
10-02-2015 08:06 AM
