Leakin Antifreez Question.
RE: Leakin Antifreez Question.
Use some common sence bra! If you get a nose bleed, you aren't gonna put a bandaid on your big toe! Look to see where the leak is coming from and then fix that! If it is coming from a hose, fix the hose! Use your head! Like pro said, its not rocket science!!!
ok man... where do you live.... maybe someone on here is close enough that theyll be able to help you out... because you need it( no offence)
ok and changin your oil... unbolt the drain plug... take off the filter... replace filter and plug... go up top and put 5 qts of 5w30 in it.(some use differant, i use 5 30)
really tho, where are you at? chances are your relativly close to someone on here w. some knowledge... and maybe theyll help you out
Its not that hard man. Just get a flashlight and start the car up and see if you can tell where its coming from. If there coolant all over get a rag and dry everything off then see where it first reappears. Like dimebag said list your location im sure if theres someone close it will only take 5 min to fix the problem or at least tell you what needs to be replaced
ORIGINAL: $Ne4k LX89
^^well i dont know if youve noticed but i dont know **** about cars... i dont even know how to change my oil and my **** is on low
stangin1996gt
09-21-2015 11:01 AM
Daddys Girls GTs
09-14-2015 08:46 PM
