airbag question
airbag question
ok...... i have to get my airbag working correctly so it will pass state inspection. i am getting a code 51(which i already know what it is) Diagnostic Monitor Internal Thermal Fuse - Open Due to Intermittent Short To Ground
here is my question. a friend of mine helped me take my steering column out last year when i converted to a t-5 from an AOD. i had already disconnected the battery and he decided to pull the fuse out for the airbag circuit under the dash (fuse #7 i believe) without telling me. guess he was affraid of the airbag coming out in his face. i dunno. anyway a month later i started getting the code 51. i hadnt had a chance to mess with it until the other day. this is when i noticed the fuse missing and i called him and he verified pulling the fuse. is it possible that this caused the diagnostic monitor to think there was a short to ground? i did find this statement online.
"PINPOINT TEST C1: FAULT INDICATION--AIR BAG INDICATOR FLASHES FAULT CODE
51--PROBABLE FAULT--LOSS OF BATTERY POWER TO AIR BAG FIRING CIRCUIT"
thanks in advance for your help
RE: airbag question
i already put the fuse back. (still has fault) you cant just clear the code, you have to replace the diagnostic monitor becausethe internal thermal fuse is open. i just dont wanna buy a new one and have it blow too. i hear these things are around $200.
RE: airbag question
All you would have to check is CKT 611 (pin 15) for a short to ground possibility before you replace the diagnostic monitor.
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
