Installing TPS
08-10-2007, 08:26 PM
Installing TPS
Does the TPS have to be wound in any way when installing it? I removed it to clean the TB, and now the idle is through the roof.
08-10-2007, 08:33 PM
RE: Installing TPS
what is the voltage?
08-10-2007, 09:12 PM
RE: Installing TPS
It is pretty much stayng at around 4.8v. Idle is a little above 3 grand, and it is a beeyach to start sometimes.
08-10-2007, 09:13 PM
RE: Installing TPS
yah, you need to align the TPS with the notch on the butterfly that it goes over.
08-10-2007, 09:31 PM
RE: Installing TPS
Hmm, I guess I will mess with it more tomorrow. It is driving me nuts thats for sure.
08-10-2007, 09:51 PM
RE: Installing TPS
the voltage should be around .9-.98v at idle i believe. there is info the tech sheets in the forums
08-10-2007, 10:00 PM
RE: Installing TPS
Yeah, I know, but I cant seem to get it there. So I did not know if it had to be wound or not.
08-10-2007, 10:21 PM
RE: Installing TPS
yes it does. it should install facing towards the front i believe, and rotate 90* back to the right.
08-10-2007, 10:27 PM
RE: Installing TPS
Great. Thanks for the help. I will try that tomorrow, and see what I get.
08-10-2007, 11:13 PM
RE: Installing TPS
If your TPS is wrong it will run like crap
