leaking oil
leaking oil
Hi guys recently my 89 mustang has been leaking a good amount of oil.I looked under the car and all the oil is dripping off of the tranny pan.Its not tranny fluid its oil so I know that.My question is what is the first thing I should do to like try and fix this?Does anyone have an idea of where its coming from?Someone mentioned to me the rear main seal.I dont kow alot about cars so any help would be appreciated.thanks.
RE: leaking oil
ya Thats what other people were saying.I have a friend that owns a tranny shop so that will work out great.Also if its not the rear main any other places you think?I am having my graduation party in 2 weeks so Im going to be coming into some money.I want to something maybe performance wise.any ideas?
RE: leaking oil
Had the low oil sensor leaking (new gasket from 5.0 Resto) and both (seriously) drain plugs (new ones from NAPA). Much better. Still need to look further at valve cover gaskets and pan gasket.
As said earlier, more time that difficulty.
Good luck!
Good luck!
RE: leaking oil
ORIGINAL: daleclough
Good luck!
Good luck!
When applying the rear main, a dab of high temp bearing grease around the seal will help extend the life and make instal a breeze. Its very easy to put these in crooked or damage them, I use a rubber mallet and block of polished wood.
RE: leaking oil
Check the rear intake gasket. That son of a bitch always starts leaking and you really can't tell where the leak is coming from until you stick your hand on the rear of the lower intake manifold and feel a puddle of oil.
bradleyb
11-27-2015 07:50 PM
