shorter belt No air pump
Old 08-11-2007, 12:54 AM
Wild_Stang
Wild_Stang's Avatar
Default shorter belt No air pump
guys if i'm going to replace the orginal belt with a shorter one to cancel the air pumpis it neccesery to for the beltto be routed as it used to be?
If the belt was kind tight does it effect the performance of the engine?
Wild_Stang is offline
Old 08-11-2007, 01:02 AM
Wild_Stang
Wild_Stang's Avatar
Default RE: shorter belt No air pump
If i baypassed the air pump would I notice white smoke comming out of the catbacks while flooring it?
Old 08-11-2007, 01:54 AM
Wild_Stang
Wild_Stang's Avatar
Ok i've figured it out and the car runs great
but i still want to know ifthe belt was kind tight does it effectengines performance?
and bypassing the smog air would it cause white smoke coming out of theline while flooring it?
Old 08-11-2007, 02:00 PM
grumpyphillips
grumpyphillips's Avatar
You shouldn't have white smoke coming out of your exhaust from just running a shorter belt. You should be using an 84.5 belt if the only thing you've bypassed is the smog pump.
grumpyphillips is offline
Old 08-11-2007, 02:14 PM
Alero99
Alero99's Avatar
stock, how many ribs on the belt?
Alero99 is offline
Old 08-11-2007, 05:03 PM
ALMOST STOCK
ALMOST STOCK's Avatar
As grumpyphillips stated you should be an 84.5 belt length and routed like so.
Check your tensioner it will tell you if your belt is to tight or not, it should be between the marks.
ALMOST STOCK is offline
Old 08-11-2007, 05:04 PM
ALMOST STOCK
ORIGINAL: Alero99
10-26-2015 05:01 PM
SteelerNation82
09-16-2015 07:11 AM
fastbackford351
09-12-2015 09:42 AM
robjh22
Suspension
09-08-2015 12:47 PM
Quick Reply: shorter belt No air pump
