tranny fluid
tranny fluid
hey guys i'm changing my tranny fluid i was wondering how many quarts of oil i needed to put in it... and is there any easy way to put it in, right now i just put a hose on the top of the bottle and i'm squeezing it lol it's a paint in the *** but it's workin i guess... but i really need to know how many quarts to put in... thanx guys
RE: tranny fluid
Hey just pulled this from the Amsoil website for you. This is assuming you have the 5.0 V8.
If not follow the link: https://www.amsoil.com/scripts/runis...msoiloaf:index
CAPACITIES
Engine, with filter..........4.7 liters[1]
Cooling System, Initial Fill..........13.0 liters
AMSOIL Antifreeze and Engine Coolant
Automatic Transmission, Total Fill..........11.8 liters
Manual Transmission, ..........2.6 liters
Differential, with 7.5 ring gear Rear..........1.5 liters[2]
Differential, with 8.8 ring gear Rear..........1.79999995231628 liters[2]
1. Some engines may have 2 oil drain plugs.
2. Others: Fill to no more than 1/4" to 9/16" below fill plug
TORQUES
Oil Drain Plug.....15-25 ft-lbs
Manual Transmission 5-SPD
Fill Plug.....15-25 ft-lbs
CAPACITIES
TORQUES
RE: tranny fluid
ORIGINAL: dimebag
dude you fill it to the bottom of the drain hole... basically as much as itll hole w. the drain unpluged
Ummm, fill it til it runs out the fill hole!! You need some sleep.[>:]
