overheating problem
overheating problem
Ok so my car is overheating and boiling coolant everytime i drive it....
what are some causes of this?
i have already change the thermostat, put the front air damp back under the radiator....
is it my 4.10's i have in the rear end? do the extra 800 rpms really affect the temperature that much?
... ok well any input would be nice..
thanks for your help
michael
michael
RE: overheating problem
fan is brand new.......i hope its not a head gasket.....
do the head gaskets just go bad occasionally? cuz i havent even done anything to make it go bad.
like driving it hard or anything...would my timnig being advanced have anything to do with it?
uh, i dont sit still long enough for it to warm up just sitting still...
so i cant say but it DOES overheat with a mix of city drivign from stop to 45 miles per hour, and highway driving (65 to 70 mph)
well if it overheats going down the road could be a clogg in the radiator or a problem with the water pump...I've seen the water pump impellers crap out on a few before ...though not as common but possible....to check for flow drop the level in the radiator tank enough so you can view the fins and when the t-stat opens up you should be able to see water rush out the fins....if all that is good and you have a t-stat that is properly installed and your fan is good....if fan where bad it would overheat sitting still and be fine driving down the highway...anyway after all externals are checked then possible a blown head gasket needs to be checked for
Ok here is a few parts that are brand new on my car..
water pump,
thermostat,
clutch fan,
front air damp under radiator,
and i can not confirm that it overheats just sitting stilll.
but it does overheat driving in town and on the highway...i dont exceed the speed limit either...
how do i do a compression test to see if its a headgasket? and would low rear gears be the problem..
making the engine rev more to achieve the speed limit...
oh and does advanced timing have anything to do with overheating?
water pump,
thermostat,
clutch fan,
