Stiff Clutch
Stiff Clutch
Peeps,
What can be done to soften a stiff clutch. I have a King Cobra Clutch and it is super super stiff. It's really hard to press. I mean I knew it was going to be hard, but it's impossible to press.
RE: Stiff Clutch
I never understood that b/c its advertised as being 10% less pedal effort than stock. If you have the stock cable and quadrant installing new ones might make it a lil easier to press.
RE: Stiff Clutch
ORIGINAL: OnyxCobra
RE: Stiff Clutch
Most quadrants are built the same....with the exception of the double/tripple pickup.. I went with an Anderson, but hear Steeda is one of the best. Also, make sure you get a kit with the firewall adjuster, makes life easier.
RE: Stiff Clutch
ORIGINAL: bbbngowc
Ebay.
ORIGINAL: cleanfitty
Where did you get the clutch from???
Ebay.
anyway like adder said, its a mustang after a few months your leg will get used to it
RE: Stiff Clutch
I've always preffered a stiffer clutch, makes it feel like more of a "muscle" car...
Anyways, just installed KC with Steeda cable kit and its alot softer than stock. Definitely try another cable/quadrant
