Is no sway bars okay?
Old 08-12-2007, 05:44 PM
fishermanjesse
fishermanjesse's Avatar
Default Is no sway bars okay?
can i run no sways front and rear for my drag car
fishermanjesse is offline
Old 08-12-2007, 05:52 PM
CantStopTheFox...
CantStopTheFox...'s Avatar
Default RE: Is no sway bars okay?
My buddy pulled his front sway bar at the track every time he made a run...reduced weight
CantStopTheFox... is offline
Old 08-12-2007, 05:58 PM
fishermanjesse
do i have to wry about twisting my frame at all?
Old 08-12-2007, 06:05 PM
AdderMk2
Banned
AdderMk2's Avatar
the sway bar wont keep you from twisting the frame.... but you should get some subframe connectors
AdderMk2 is offline
Old 08-12-2007, 06:08 PM
fishermanjesse
i bout somw with the T's and the T's weren't assembled with them wondering if i really need the t's
Old 08-12-2007, 06:13 PM
90lxrider
90lxrider's Avatar
you dont remove the sway bar for weight reduction ....remove it for more weight transfer to the rear wheels
90lxrider is offline
Old 08-12-2007, 06:18 PM
fishermanjesse
that s what i was going to use it for weight transfer!
Old 08-13-2007, 11:11 AM
luckythirteen13
luckythirteen13's Avatar
you remove the front one, keep the rear. there is a reason they make anit-roll bars for drag cars
and yes, an anit-roll bar is different fromthe stocksway bar
luckythirteen13 is offline
Old 08-13-2007, 06:23 PM
tinman
tinman's Avatar
Sh-t-can the front sway bar. Not only does it bind up wieght transfer it does wiegh something and you don't want an extra once on the front of a Fox body car.
I use an 'anti-roll' bar on the rear of my car but if you are mostly stock, I would keep the factory bar...............
tinman is offline
Old 08-13-2007, 07:26 PM
ZachW04Stang
ZachW04Stang's Avatar
I don't run the sway bars on my car. I removed the rear since my upr lower control arms don't have provisions for it.
ZachW04Stang is offline
Quick Reply: Is no sway bars okay?
