ok so i changed waterpump today i put my antifreeze in an the low coolant light comes on so i was just gonna add water to the recovery resivor an when i did i was not paying attention an filled it up to the brim so i guess i just let some out of radiator drain plugbut i was wondering is there any other was that is not so messy
Get a pump with a long hose and siphon it out into an clean container. Probably the leaast amount of mess. If the container is really clean you could use the extra freeze later.
just pop the hose going from the radiator to the overflow tank off and pull it down. Once you pull that hose down below the water level in the overflow the water will start coming out
