Smoke coming from vent - Help!
Old 08-15-2007, 05:55 AM
85GTsleeper
85GTsleeper's Avatar
Default RE: Smoke coming from vent - Help!
heater core. its not too bad replacing it just takes a few hours and a good memory of where everything goes. when i replaced mine i took pictures with my cell to help me remember where to put things.
85GTsleeper is offline
Old 08-15-2007, 03:06 PM
blackout
blackout's Avatar
bump...
Again any reason why this would happen right after H/C/I? Also when it is smoking I can hear something like it is running, like the A/C is on or something like that when it is in fact turned off...
Where can I get a heater core and any install instructions? I still don't think this is the problem and would be extremely disappointed if I replace it and that is not the problem...
Was I supposed to do something after I had let the car sit for a few days swapping my heads and all that? Did I do something wrong, because this happened the first time I tried to put my A/C on all this smoke came out... Was I supposed to recharge my A/C or do something with that.
blackout is offline
Old 08-15-2007, 06:23 PM
blackout
blackout's Avatar
bump... help me out guys!
blackout is offline
Old 08-15-2007, 09:46 PM
blackout
blackout's Avatar
I guess last try...
blackout is offline
Old 08-15-2007, 09:58 PM
crazyhorse
crazyhorse's Avatar
if this is coming off the ac like mine was, it is NOT smoke, it is more like a fog forming when heat & cool meets. if it is a heater core you should be losing radiator coolant, the windows should be foging up, the carpet may be wet at passenger feet,you may have a "sweet" smell inside you car. make sure it is the heater core before you replace it .good luck. luk.
crazyhorse is offline
Old 08-15-2007, 10:09 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
ORIGINAL: nothsa
Maybe you damaged the core when doing the h/c/i. Here's a link for you. Git rdone!!!
http://www.mustangmonthly.com/howto/5652/
PRO50SC is offline
Old 08-16-2007, 12:08 AM
blackout
blackout's Avatar
ORIGINAL: PRO50SC
ORIGINAL: nothsa
How could I damage it during the H/C/I, all I did was remove the two hoses...
I do think this is the problem since I do smell coolant while driving sometimes and there was a huge puddle of coolant on the ground outside of my car when I stopped at block buster one day.
For now i'm just going to bypass the two heatercore lines for about two weeks so I can do the install...
-Jeff
blackout is offline
Old 08-16-2007, 12:11 AM
blackout
blackout's Avatar
Could it be one of the heater hoses is punctured causing the heatercore to not work correctly? All I have to do is check which I will but it's weird that my floor isn't drenched since the core should be toasted...
-Jeff
blackout is offline
Old 08-16-2007, 01:16 AM
onetrickpony
onetrickpony's Avatar
**** it. Sell the dam thing.
onetrickpony is offline
Old 08-16-2007, 01:18 AM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
ORIGINAL: nothsa
ORIGINAL: PRO50SC
ORIGINAL: nothsa
-Jeff
That's how. The reason it's probably not making it to the carpet is b/c it's running out your a/c drain first. Consider yourself lucky in that respect.
PRO50SC is offline
Quick Reply: Smoke coming from vent - Help!
