Smoke coming from vent - Help!
#21
RE: Smoke coming from vent - Help!
ORIGINAL: PRO50SC
That's how. The reason it's probably not making it to the carpet is b/c it's running out your a/c drain first. Consider yourself lucky in that respect.
ORIGINAL: nothsa
How could I damage it during the H/C/I, all I did was remove the two hoses...
I do think this is the problem since I do smell coolant while driving sometimes and there was a huge puddle of coolant on the ground outside of my car when I stopped at block buster one day.
For now i'm just going to bypass the two heatercore lines for about two weeks so I can do the install...
-Jeff
ORIGINAL: PRO50SC
Maybe you damaged the core when doing the h/c/i. Here's a link for you. Git rdone!!!
http://www.mustangmonthly.com/howto/5652/
ORIGINAL: nothsa
bump... help me out guys!
-Jeff
Pro I didn't remove the hoses from the heatercore. I only removed them from the opposite end.
-JEff
