What RPM do you shift at on Average? Curious
Old 08-15-2007, 03:33 PM
1985stang
1985stang's Avatar
Default RE: What RPM do you shift at on Average? Curious
ORIGINAL: FivePointOhh
ORIGINAL: blk40th
after i adjusted my timing i took the car out and it reved so fast to 7k but it pulled all the way, i will never do that again cuz its way to much.
i hope you have something to justify that 7k rev......
A need....for speed? [8D]
1985stang is offline
Old 08-15-2007, 03:39 PM
blk40th
blk40th's Avatar
what do you mean something to justify that? i took the car out after adjusting the timing and it just reved fast as hell. as soon as it reved i let go though. changed the oil and all but everything held together ok.
blk40th is offline
Old 08-15-2007, 04:01 PM
FivePointOhh
in limbo
FivePointOhh's Avatar
ORIGINAL: blk40th
....honestly i dont buy it. 7k and you couldnt even stop it? i will admit first gear goes quickly but almost 2G's more than you should be going. i find that hard to believe. can you even rev that high? what kind of ignition are you running?
FivePointOhh is offline
Old 08-15-2007, 04:05 PM
85GTsleeper
85GTsleeper's Avatar
daily driving 1.5-2k shift, messing around 5500, when im using nitrous i shift at 5000.
85GTsleeper is offline
Old 08-15-2007, 05:32 PM
Jfsram
Jfsram's Avatar
On a stock, with external bolt ons, 93 coupe. Elec fan, underdrives, long tubes, cold air.
During daily, trying to conserve fuel, I try to keep it around 2 grand, 2500 tops. Often taking off in 2nd, then 4rth, then 5th.
Uphill, I always take off in 1st.
Spirited driving. My shift light is often lit. It's set at 4600 and when my tires are burning, the light is on.
At the track I shift at 4800rpm. Tried 5200rpm, because that's what felt good but my times suggested 4800 is faster.
First runs were 14.0@100 and by the end of the day I went 13.6@102mph.
Jfsram is offline
CS2007
06-25-2019 09:45 PM
Thunderball
15
11-22-2015 11:49 PM
Explosive
10-02-2015 07:45 AM
09-25-2015 09:06 AM
lmurf60
09-24-2015 10:07 PM
Quick Reply: What RPM do you shift at on Average? Curious
