Need help identifiying C4
Old 08-15-2007, 08:54 PM
crazyhorse
crazyhorse's Avatar
Default RE: Need help identifiying C4
correct me if i am wrong [been a long time] but i think a c4 separates from the bell housing.
crazyhorse is offline
Old 08-15-2007, 09:10 PM
my77stang
my77stang's Avatar
yeah easiest way to separate a C4 and C6 is the C4's bellhousing comes off and the C6 bellhousing is cast into the rest of the case.
my77stang is offline
Old 08-15-2007, 09:14 PM
89Ford
89Ford's Avatar
how about aod and c4
89Ford is offline
Old 08-15-2007, 09:23 PM
89Ford
89Ford's Avatar
and what do i need to do to make it race preped
89Ford is offline
Old 08-15-2007, 09:32 PM
Blckstng93
Blckstng93's Avatar
ORIGINAL: 89Ford
the only difference between a c4 and c5 is just the internals?
Yes. If the tags are missing or whatever, the C4 has a filter with the valve body, a C5 will have what looks like 2 valve bodys one on top of the other along with the filter. The C4 was used from 64 to 82 and then replaced by the C5 which in turn was replaced in 86 by the AOD*. The C3 was basically a light duty C4 used from 74 to 86. The C3, C4, and C5 have a seperate bell. The AOD has the bell and case cast as one piece, and as My77stang stated, the C6 bell and case are cast as one piece also.
*A sidenote on the AOD. The AOD didnt show up until about 84 in the Mustang with the EFI 5.0 motors. An AOD has 'Automatic Overdrive Metric' stamped onto the pan. Easy to spot.
Blckstng93 is offline
jc122078
12
06-19-2012 09:41 AM
4stfed
12-12-2010 07:49 AM
phutch11
12-04-2009 07:51 AM
blueovalfan
08-15-2007 03:19 PM
shr
07-23-2007 11:27 AM
Quick Reply: Need help identifiying C4
