94 Cobra High Oil Pressure
Old 08-18-2007, 12:19 PM
Boozshey
Boozshey's Avatar
Default 94 Cobra High Oil Pressure
I got a '94 Cobra who's oil pressure is at the max of the gauge. Where should I start?
Boozshey is offline
Old 08-18-2007, 01:01 PM
WhiteWindsor
WhiteWindsor's Avatar
Default RE: 94 Cobra High Oil Pressure
If it is a factory guage, i would start with buying a mechanical guage and then see where your at.
WhiteWindsor is offline
Old 08-18-2007, 01:16 PM
Boozshey
Boozshey's Avatar
Would I just connect that to the white/red striped oil sending unit wire then?
Boozshey is offline
Old 08-18-2007, 01:53 PM
ahittz24
ahittz24's Avatar
I would actually start with an new oil pressure sending unit.... they are known for going bad
ahittz24 is offline
Old 08-18-2007, 02:44 PM
Boozshey
Boozshey's Avatar
Sending unit should be easy enough, I guess I will change the oil at the same time. I bought the car a couple months ago, haven't drove it much, but don't have any idea when the oil was changed last either...
Boozshey is offline
Old 08-18-2007, 02:53 PM
CrazyCobraSpeed
CrazyCobraSpeed's Avatar
stock sending unit and gauge sux... mine only works have the time and when it does its pretty much at max as far as the guage goes... my after market gauge however reads a good 45-50 depending on how hot hte oil is of course... hot oil less pressure becuase the viscosity goes down u can keep you old sending up like i did... just get some piping and a T connector so u can screw both sending units in... get an autometer guage... what color doesnt really matter i like mine and it was only like 45 bucks form summit and since im running a s/c now its pretty cheap insurance... i sitll need get a fuel pressure gauge tho... and there is about a thousand and one different way to mount it so thats kind of optional on which way you go... i have a pillar and a cluster... 4 gauges... soon to be five in a months or less
CrazyCobraSpeed is offline
Old 08-18-2007, 11:51 PM
OnyxCobra
OnyxCobra's Avatar
I know my oil pressure gauge is definitely towards the high side of the gauge, never gave it a second thought actually.
OnyxCobra is offline
Old 08-18-2007, 11:54 PM
AdderMk2
Banned
AdderMk2's Avatar
use a thinner oil
AdderMk2 is offline
Old 08-23-2007, 05:37 AM
5.0fuz
5.0fuz's Avatar
would the sending unit be the first place to start for low oil pressure as well?
5.0fuz is offline
Old 08-23-2007, 07:09 AM
dillon1340
dillon1340's Avatar
ORIGINAL: 5.0fuz
yes.
dillon1340 is offline
Quick Reply: 94 Cobra High Oil Pressure
